Activity Forums Adobe After Effects Expressions selectLayers script
  • selectLayers script
    Posted by Scott Mcgee on July 31, 2018 at 10:39 am
    I understand that selected layers, requires a bit more brain hurt, but to get a selected item
    for(var i = 0; i <= 3 ; i++ ){
    b[i].onClick =
    (function(i){
    return function() {
    app.beginUndoGroup(“AddEffect”);
    var curItem = app.project.activeItem;
    var selectedLayers = curItem.selectedLayers;
    try{
    var curRem = curItem.selectedLayers[0].effect.property(“Fill”).remove();
    var curLayer = curItem.selectedLayers[0].Effects.addProperty(“ADBE Fill”)(“Color”).setValue(pcolor[i])
    }catch(err){
    var curLayer = curItem.selectedLayers[0].Effects.addProperty(“ADBE Fill”)(“Color”).setValue(pcolor[i]);
    app.endUndoGroup();
    })(i);
    This works brilliantly, but I’ve tried a few different ways to select multiple layers and get it to work, but the
    })(i);
    part towards the end, keeps flagging errors with me.
    Any ideas?
    Scott Mcgee replied 8 years, 1 month ago 2 Members · 7 Replies
  • 7 Replies
  • James Ronan
    August 1, 2018 at 4:38 pm
    I’m not 100% following your code, but the “curItem.selectedLayers[0]” parts will mean it will only affect the first layer selected.
    You could try adding a for loop, going through your selected layers to affect all of them:
    var curRem, curLayer;
    for (var j = 0; j < selectedLayers.length; j++) {
    try {
    curRem = selectedLayers[j].effect.property("Fill").remove();
    curLayer = selectedLayers[j].Effects.addProperty("ADBE Fill")("Color").setValue(pcolor[i]);
    catch (err) {
    Hope that helps!
  • Scott Mcgee
    August 2, 2018 at 12:06 pm
    Nearly there.
    I can highlight multiple layers, but the first one I selected. Is the only one getting the fill added.
    my first loop
    b[i].onClick = (function(i){
    I have 25 buttons, I couldn’t be bothered to have 25 buttons written individually. So I created a loop (Test above I did on four) which in the above case has four buttons . So that part of the loop is to recognise which button I pushed.
    I’ve assigned each button to an array. Button1 is [0] button2[1] …etc
    The issue was without (i) at the bottom of the expression, it would add the fill but would reference the array to button and add that colour.
    What I want to do now is upgrade it to select several layers. Hit the button and [i] then gets added to all. If that helps make a bit more sense.
  • Scott Mcgee
    August 2, 2018 at 12:07 pm
    I say my first loop. I mean my only loop.
    But I know I need to add a second loop and that’s where I’m struggling.
  • Scott Mcgee
    August 2, 2018 at 12:13 pm
    Ignore everything I said. I can’t have deleted one little something. That’s all working. Thank you very much.
  • James Ronan
    August 2, 2018 at 2:27 pm
    Hey Scott.
    Here’s a rough example of a window with 3 buttons, that adds or replaces the fill effect across all selected layers:
    Hope that helps!
    var win = new Window('dialog', "Test");
    var btnAry = [];
    var colAry =
    [1, 0, 0],
    [0, 1, 0],
    [0, 0, 1]
    var clickHandlerFill = function(i) {
    return function() {
    app.beginUndoGroup("AddEffect");
    try {
    curLayer = selectedLayers[j].Effects.addProperty("ADBE Fill")("Color").setValue(colAry[i]);
    catch (err) {
    app.endUndoGroup();
    // Create buttons and assign clickHandler
    for (var i = 0; i < 3; i++) {
    btnAry[i] = win.add('button', undefined, i);
    btnAry[i].onClick = clickHandlerFill(i);
    win.show();
  • James Ronan
    August 2, 2018 at 2:31 pm
    Ah, hadn’t seen your later messages.
    No worries, glad you got it working!
  • Scott Mcgee
    August 2, 2018 at 3:47 pm
    That is much tidier than what I have and makes a lot more sense.
    Mine still works, but I’ll adapt it to be more like yours as it looks less clunky. I think I’ve just gone an arse uppard way of doing it haha.
    cheers for the help
