Activity Forums VEGAS Pro Selectively selecting multiple anchor points in the mask
  • Selectively selecting multiple anchor points in the mask
    Posted by Travis Taylor on September 23, 2010 at 3:47 pm
    So, most every software that deals with anchor points will allow you to selectively select anchor points, either with a selection tool or by holding a hot key and clicking the anchor points you want. Vegas, I’m sad to say, doesn’t have a selection tool for masking (although that’d be a fine addition to future versions of Vegas). The instruction manual says to “Hold Ctrl while clicking to select/deselect multiple points” while in normal mode in the mask. Unless I’m doing something wrong, this does NOT work. The cursor changes to Split Tangents cursor (the upside-down V).
    So is there any way to selectively select multiple anchor points? I have a rounded box that would be much easier to resize/move if I could select just one corner (made up of a group of 3 anchor points) at a time.
    Travis Taylor replied 16 years ago 2 Members · 2 Replies
  • Mike Kujbida
    September 23, 2010 at 4:35 pm
    Use the Shift button instead of the Ctrl button and you can do what you want to do.
  • Travis Taylor
    September 23, 2010 at 4:40 pm
    Awesome, thanks! That was simple enough. I thought I had tried every basic hot key, but I guess I was expecting the anchors to actually become highlighted once multiples were selected (which, as it turns out, is not the case).
    Thanks again 🙂
