Activity Forums VEGAS Pro Selective two-edge borders in Sony Vegas Pro 10?
  • Selective two-edge borders in Sony Vegas Pro 10?
    Posted by Tor Wong on August 1, 2011 at 6:31 pm
    Friendly greetings! This seems like a straightforward enough problem, but I suspect I’m missing something simple:
    I’d like to effect a clip and show a border on only TWO sides. For example, the right and the bottom edge. Vegas has a Border effect which applies a border around every edge. If I select the Beveled option, I can get somewhat nearer because with certain angles (like 225 degrees) and color set to white, it does look like a border only goes across two edges: https://screencast.com/t/aVqC39uhJ5vA
    But it still seems kind of kludgy. Does anyone know a more elegant approach? Even better if there’s a way to make just the border glow. Thanks in advance.
    Tor Wong replied 15 years, 1 month ago 4 Members · 5 Replies
  • Stephen Mann
    August 1, 2011 at 9:52 pm
    I would make the frame in Photoshop and put it on the top layer of your project.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Danny Hays
    August 2, 2011 at 12:16 am
    You could also use event pan and crop to crop off the two sides you don’t want, and stay in Vegas.
  • Tor Wong
    August 2, 2011 at 2:09 pm
    Thanks guys! My followup thoughts:
    @Stephen That makes sense to me but here’s a tricky thing: I want each of the four “picture in picture” clips to originally encompass the entire canvas, then zoom out and slide into each corner. So with a Photoshop layer on the top layer, looks like I’d have to fade that in at the right time.
    @Danny I’ll try some experimenting with that, although I was hoping for a more stylized and aesthetically striking approach (hence my mention of “glow”). I’ve also looked into existing tools like VideoWall, although I haven’t found the flexibility I’d like — is there a more advanced borders plugin with keyframing? (I’ve found various one for Photoshop, but seems to be a gap in the video market?)
  • Jerry Irving
    August 4, 2011 at 4:37 pm
    An idea to try:
    In this test, border will show on bottom & right edges only.
    -In timeline, select desired event.
    -In pan/crop make clip smaller to show black (background) on top & left edges only. (Width of black should be same as desired width of border.)
    -Apply border.
    -In Track Motion, move edited event up & left and increase dimensions until event with borders on bottom & right fill the frame.
  • Tor Wong
    August 8, 2011 at 5:35 pm
    An intriguing suggestion. Thanks Jerry, I’ll give this a go!
