Activity Forums Adobe After Effects Selective Turbulence Displace
  • Selective Turbulence Displace
    Posted by Emma McKell on January 17, 2022 at 1:33 pm
    Hello!
    I’m trying to create the effect seen in the attached illustration of rippling water on straight lines. I’ve tried adding a Turbulence Displace effect on an adjustment layer on top of the straight lines, also tried adding masks with feather, but it always creates a cut off between the rippling lines and the straight ones which isn’t the desired look I’m going for (see screenshot of my attempt). If anyone can help me I’d be greatly appreciated as I’ve been at this for a day and can’t seem to figure out how to make it work.
    Emma McKell replied 4 years, 7 months ago 3 Members · 4 Replies
  • Andy Kiernan
    January 17, 2022 at 4:23 pm
    Try Distort> Displacement map, use a greyscale image to drive the displacement (make a pre-comp of a black solid with a white blurred/feathered shape when you want waves) add-in noises, etc to randomize it/ make it wavey.
  • Greg Gesch
    January 17, 2022 at 11:20 pm
    Hi Emma, you could also look at the Liquify effect which can be keyframed.
  • Emma McKell
    January 23, 2022 at 9:48 pm
    This worked like a charm! Thank you so much for your help 🙂
  • Emma McKell
    January 23, 2022 at 9:49 pm
    Thank you Greg! This also worked but managed to control better with a displacement map in the end. Handy one to know for future though!
