Activity Forums Adobe After Effects Selective coloring
  • Selective coloring
    Posted by Carl Fritzell on September 22, 2008 at 10:04 am
    Hi all!
    Just wanted to see if there is someone out there who can help me with this question.
    I’m putting together some footage that is going to be in black and white. But I want some objects to be in color (like in Schindlers List and Sin City. The color of these objects stands out pretty good so is there anyway one can do this without masks?
    Regards
    Carl Fritzell
    Grant Swanson replied 17 years, 11 months ago 3 Members · 2 Replies
  • Mark
    September 22, 2008 at 10:18 am
    You can use the leave color filter which will allow you to target a specific color, and desaturate the other colors…this is pretty much what you said you wanted, but there is also a better way which allows for more flexibility…
    I use the change color filter.
    I start by duplicating twice my layer, then I apply the change color filter to the uppermost layer. I select the color, then select color correction matte from the view pulldown. Next I use this track as a track matte for the 2nd layer using luminance as the type of track matte. Now I add the Hue/Saturation filter on the bottom layer and desaturate….so basically this gives you the same look as the leave color……the big advantage to this method is that you can now tint the bottom layer or adjust it’s levels etc without affecting the color that you left….and for interesting reaults, you can transfer mode the colored layer back onto the black and white layer.
    Hope this helps
    Mark
    Mark Harvey
    Senior Editor
    Le R
  • Grant Swanson
    September 22, 2008 at 2:59 pm
    I created a tutorial on how to do this a while back available here.
    Grant Swanson
    Visual Effects Supervisor
    Video Apex – Minneapolis, MN
    videoapex.blogspot.com
