Activity Forums Adobe After Effects Selective color like photoshop
  • Selective color like photoshop
    Posted by Marcelo Paz on March 28, 2008 at 12:59 pm
    Hello… I want to know if after effects has a process like “selective color” in photoshop, to change each color separetly as I want… or any plugin you know? how can i do it?
    thanx
    Danny Parsons replied 18 years, 5 months ago 2 Members · 1 Reply
  • Danny Parsons
    March 28, 2008 at 5:39 pm
    The Photoshop ‘Selective Color’ adjustment uses CMYK (although it can still be used on RGB images). After Effects only works with RGB, so any color-correction filters use the RGB model.
    If you’re using PS CS3 Extended, you could open the video file and apply the Selective Color adjustment within Photoshop, or if you’re using an older version (or the ‘non-Extended’ version of CS3), you could still batch-process an image-sequence in PS before opening it again in AE.
    Cheers,
    DP
