Activity Forums Adobe After Effects Selective blendmodes
  • Selective blendmodes
    Posted by Ramin Bahari on March 30, 2007 at 10:13 am
    Here’s my setup: 3 layers. I want the top layer to use the layer blend mode Luminosity but I dont want the blend mode effect 2nd layer, at the same time I want to keep the layers in the same order.
    This is probably confusing, so here is a screenshot.
    https://ramin.nl/screenshot.jpg
    Is there an option to let the 3d layer use luminosity on the 1st only? Or do I have to precomp and mask?
    Darby Edelen replied 19 years, 6 months ago 3 Members · 3 Replies
  • Danny Princz
    March 30, 2007 at 12:35 pm
    set the trk matte on the bubbles to use the arc as an inverted alpha.
    who is that masked man…
  • Ramin Bahari
    March 30, 2007 at 6:33 pm
    I thought one can only use the above layer as t-matt ?
  • Darby Edelen
    March 30, 2007 at 6:48 pm
    [Ramin Bahari] “I thought one can only use the above layer as t-matt ?”
    If the layer you want to use as a track matte is below the layer to be matted, you can duplicate the layer you want to use, put it above the layer you want to matte and parent it to the original (lower) layer.
