Activity › Forums › Adobe Photoshop › Selections, the inverse, and the extra pixels
  • Selections, the inverse, and the extra pixels
    Posted by Brett Sneed on June 20, 2006 at 1:46 pm
    I am cutting some shapes out of a photo so I can animate in AE. I take my photo, dupe it, make a selection/mask on the dupe. I then inverse the selection and delete, leaving me my object. I then go to the original layer, inverse the selection again, and delete, to cut a hole. In AE, I then animate the object from off screen into its correct position.
    The problem: there is a thin outline of empty space around my object. Its as if the “marching ants” actually have a thickness. Why don’t a selection and its inverse, when combined, make a perfect whole?
    Is there a way I can make it so it is perfect, so that the mask doesn’t have this pixel overlap property?
    Richard Harrington replied 20 years, 2 months ago 2 Members · 1 Reply
  • Richard Harrington
    July 4, 2006 at 4:29 pm
    Run a levels adjust ment on the mask and choke it… or choose select > modify > contract
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
