Activity › Forums › Adobe Photoshop › selection corners
  • selection corners
    Posted by Craig Anderson on September 17, 2005 at 3:06 am
    I know this is a ridiculous problem to have, but I have checked the manuals and can’t find a thing on it. If I have a rectangular selection that I choose to modify, by expanding, or border, say, it takes what was a perfect corner and cuts it at a diagonal (stair-steps it). This is not really a video related question, as this is a portfolio for a designer, but I hope someone here knows how to get square corners when modifying, without going to manually fix each corner.
    Any help would be muchly appreciated.
    Craig
    Richard Harrington replied 21 years ago 2 Members · 1 Reply
  • Richard Harrington
    September 17, 2005 at 3:28 am
    Expand grows out alogn the pixel path… so it rounds out (or stair steps)
    Use Select>Transofrm Selection (just liek Free Transform) You can drag handles or specify size in options bar
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
