Activity Forums Apple Final Cut Pro Legacy “selection contains no video”
  • “selection contains no video”
    Posted by Lee Mceachern on June 18, 2007 at 6:08 pm
    Hi all,
    I got this error message — “selection contains no video” — when I tried to use Compressor. I have the inpoint and outpoint properly set on the timeline and there is definitely video in my selection. I can play the video and I can export via Quicktime conversion. But when I try to export using Compressor I get that error message. I also tried on a different section of the timeline and got the same error.
    Any thoughts as to what I might be doing wrong?
    Thanks.
    — Lee
    David Roth weiss replied 19 years, 2 months ago 3 Members · 5 Replies
  • David Roth weiss
    June 18, 2007 at 6:10 pm
    Besides your in and out points you also must have one or more audio clips selected on the timeline. Click in any gray space to deselect clips.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Lee Mceachern
    June 18, 2007 at 7:05 pm
    Hi David. Thanks for taking the time. Unfortunately no luck, however. I deselected all clips and then selected the audio clip that lives inside of my in and out points. I still go the same error message from Compressor. I tried other alternatives — deselecting all clips, etc. — but never solved the problem. I assume this is operator error since I have only used Compressor a couple of times. But I know the error message, itself, must be incorrect because there certainly is video and audio in my selection. Any other thoughts appreciated.
    — Lee
  • Steve Boultbee
    June 19, 2007 at 3:35 am
    I’ve seen this message when exporting to Compressor as well. What you want to do is this: in the Browser, select the sequence that you’re trying to export. Then, go to File -> Export -> Using Compressor.
  • Lee Mceachern
    June 19, 2007 at 3:55 pm
    Thanks Steve. You were right. I figured it was operator error.
    I think this detail…having to select the sequence in the Browser…is a little silly. Why is there a need to do that? Nevertheless, I’m glad to you took the time to let me know about it.
    Cheers,
    Lee
  • David Roth weiss
    June 19, 2007 at 4:19 pm
    [leemce] “having to select the sequence in the Browser…is a little silly. Why is there a need to do that?”
    Lee,
    You shouldn’t really need to do that. That would preclude one from frame accurately selecting to encode parts of a timeline with Compressor from within FCP. Don’t know what’s up, because it sounds like you were doing everything properly. It works properly here, I just tested it again to make sure.
    David
    “No job is worth doing more than once…”
    David Roth Weiss
    Los Angeles
