Activity Forums Apple Final Cut Pro Legacy selection contains no media
  • selection contains no media
    Posted by Chris Gallaway on August 30, 2007 at 5:15 am
    FCP is bogging down on me while I try to get a movie finished. Whenever I compress the video in a sequence, if I go back to that sequence later after making changes and try to re-compress it, the software tells me there is no media selected. Sometimes cutting and pasting the video in the sequence into a new sequence solves the problem, but now even that isn’t working. Where is this coming from, and how can I fix it?
    thanks, cg
    Jerry Hofmann replied 19 years ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 30, 2007 at 1:57 pm
    If you’re talking about rendering effects, you need to turn on the appropriate checkbox in the sequence/render menus (render all, render selected etc…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
