Activity › Forums › Maxon Cinema 4D › selection codes for extruded type
  • selection codes for extruded type
    Posted by Subspecies on September 13, 2006 at 1:07 am
    hi all,
    does anyone know the selection codes for the extrude type?
    for example, when i extrude type i can type R1 in the selection box of the particuar material that i want to be the rounded corner…
    but what about the sides or the cap? anyone know these codes?
    i know you can do this easily with the make object editable button, but it’d be nice to not do this incase the type needs to change…
    any help is appreciated.
    thx
    Brian Jones replied 13 years, 5 months ago 3 Members · 3 Replies
  • Brian Jones
    September 13, 2006 at 1:34 am
    R1 – R2 the roundings
    C1 – C2 the caps
    For the sides just put on the desired texture with no code but make sure it’s the first one so it’s not ‘on top’ of the other textures.
  • Andrew Shishkin
    April 8, 2013 at 8:41 am
    Thank you very much for the hint.
    Can I use this tags to any extruded nurbs?
  • Brian Jones
    April 8, 2013 at 2:50 pm
    yes SweepNurbs, LoftNurbs and MoText objects as well (and Lathes but that seems to be a special case – you only get caps when you lathe a closed spline and don’t lathe it 360°)
