Activity Forums Maxon Cinema 4D Selecting Viewports (w/o deselecting objects)?
  • Selecting Viewports (w/o deselecting objects)?
    Posted by Joe Walker on October 17, 2011 at 8:16 pm
    The title says it all. I have objects selected and I’d like to render a frame from a different viewport (perspective then camera and so on) without unintentionally selecting an object or deselecting the ones I already have selected. I know I can click on the grey area in the title bar of each viewport but I need the keyboard shortcut for this.
    I ran into this problem with Maya and it turned out to be as simple as hitting the spacebar while hovering the cursor over the viewport – not so in C4D-R13
    Anyone?
    Thanks in advance.
    Joe Walker replied 14 years, 10 months ago 3 Members · 6 Replies
  • Adam Trachtenberg
    October 17, 2011 at 8:58 pm
    F1 – F4
  • Joe Walker
    October 17, 2011 at 9:52 pm
    Thanks, but that brings the viewports to a single pane view. I need to stay in a four pane setup and switch between which is active.
  • Brian Jones
    October 17, 2011 at 11:27 pm
    the hover the cursor and hit the spacebar works here (R13), it also swaps the tool but Option(Alt)-spacebar changes the widow focus without swapping tools. You can also Option(Alt)-click on the windows without selecting/deselecting objects
  • Adam Trachtenberg
    October 17, 2011 at 11:29 pm
    Ah … sorry. Not sure if this is what you’re after (editor render or PV render?), but you don’t have to make a viewport window active to render it’s editor view. Just place the cursor in the view and hit Ctrl+R. That view will render even if another view is highlighted. No clicking required.
  • Joe Walker
    October 17, 2011 at 11:31 pm
    THANK YOU!!!
  • Joe Walker
    October 18, 2011 at 12:20 am
    Even better! Thanks!
