Activity › Forums › Adobe Photoshop › Selecting type to make alpha problem
  • Selecting type to make alpha problem
    Posted by Mark Sullivan on October 31, 2006 at 10:13 pm
    I have text with a drop shadow. There is no background. I want to use this in AVID so I save it as a psd file. AVID opens it fine, but the drop shadow appears white instead of black.
    If I try to use a black background and command-click the icon to select it and then generate a alpha channel, the drop shadow isn’t selected. Same if I have applied a stroke to the text.
    Suggestions will be most appreciated.
    Thanks, Mark
    Jim Kanter replied 19 years, 10 months ago 2 Members · 3 Replies
  • Jim Kanter
    November 5, 2006 at 3:48 am
    Apply the drop shadow in the Avid.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Mark Sullivan
    November 6, 2006 at 9:39 pm
    I’m on Symphony Nitris – it doesn’t do soft offset drop shadows.
    Thanks though.
  • Jim Kanter
    November 14, 2006 at 8:35 pm
    Photoshop layer styles are stored separately from the pixel content so they are usually not correctly drawn by non-Adobe apps. You should convert them by rasterizing the layer and then you should be able to select the shadow pixels normally as you would the text pixels.
    Jim Kanter,
