selecting tracks with the keyboard in track view
Posted by Terence Kearns on October 18, 2012 at 3:01 amCan someone tell me if there is a keyboard shortcut I can use for switching/selecting tracks in track view? I couldn’t seem to find it in the Customize Keyboard dialog.
Cheers.
Graham Bernard replied 13 years, 11 months ago 2 Members · 5 Replies -
Graham Bernard
October 18, 2012 at 7:02 amHmmm, help me here. Do you want to :
Select in Track Header:-
Track1 then Track2 then Track3 or any variation/combination thereof?
If you’re already at the Track Header at say Track2, then using the UP and DOWN arrows you can Navigate . . UP and DOWN. But you may want something more – maybe?
Grazie
Graham Bernard
October 18, 2012 at 7:27 amIf you are at the on an Event already, then us this KB combo:-
Alt+Shift+UP or DOWN Arrow
Works extremely well.
Grazie
Terence Kearns
October 18, 2012 at 8:02 amWell you know how you can press UP and DOWN to navigate the tracks once the track header has focus? Well I want a shortcut key that will work all the time without having to click in the header first.
If I have to click in the header first so that it can get focus, then there’s no point even having a keyboard shortcut. You’ve already had to reach for the mouse.
I think a lot of these issues are stemming from the fact that keyboard shortcuts don’t work unless you have selected the relevant area of the application. This is tedious for a program which is otherwise super-efficient.
Keyboard shortcuts should work globally. Perhaps there is a plugin which fixes this?
For instance, I want the WASD keys to navigate events in the track view (regardless of where I clicked last). WASD is used in first-person shooters (FPS games) to navigate so it’s natural for anyone who’s ever played a FPS on a PC.
(A=left, D=right, W=up, S=down). The arrow keys are already thoroughly used up for other (similar) navigation and I don’t want to change those. I want my left hand to navigate as well as my right (arrows).I just want to work faster.
Terence Kearns
October 18, 2012 at 8:05 amDoes not work for the default keyboard config in Vegas 12.
It’s doing something else (not sure what it’s doing actually). It’s not switching tracks.
Graham Bernard
October 18, 2012 at 2:38 pmJust rechecked in VP11 too. Working there.
What do you mean : –
[Terence Kearns] “Does not work for the default keyboard config in Vegas 12.”
Please explain.
Garzie
