selecting render queue items via script
Hi
i’m looking for a way to select items in the render queue via script.
i’m creating a listBox that contains all the RQ items ( i need to list them in a simpler way then the RQ window, and i’m keeping the index number of each item), and i want to select from that list items and select them in the RQ.
ideas?
thanks
Drortry{function createUserInterface (thisObj,userInterfaceString,scriptName){
var pal = (thisObj instanceof Panel) ? thisObj : new Window("palette", scriptName,
undefined,{resizeable: true});
if (pal == null) return pal;var UI=pal.add(userInterfaceString);
pal.layout.layout(true);
pal.layout.resize();
pal.onResizing = pal.onResize = function () {
this.layout.resize();
if ((pal != null) && (pal instanceof Window)) {
pal.show();
return UI;
};{var res ="group {orientation:'column',\
alignment:['fill','fill'],\
alignChildren:['fill','top'],\
folderPathListbox:ListBox{\
properties:{\
multiline:true,\
multiselect:true,\
numberOfColumns:6,\
showHeaders:true,\
columnTitles: ['#','OM','Date','Time', 'Comp Name', 'Render Path']}\
buttonGroup:Group{orientation:'row',\
alignment:['fill','bottom']\
alignChildren:['fill','bottom'],\
buttonPanel: Panel{\
text:'Actions',\
orientation: 'row',\
refButton: Button{text:'Refresh'}\
dupButton: Button{text:'Duplicate'}\
selButton: Button{text:'Select in RQ'}\
expButton: Button{text:'Export'}\
searchPanel: Panel{\
text:'Search',\
searchBox: EditText{text:'search by fileName'},\
searchButton: Button{text:'Search'}, \
function listRQ (rqList){
try{
var folderPathListbox = rqList;
var proj = app.project;
var totalRenderQ = proj.renderQueue.numItems;
for(var i= 1; i<=totalRenderQ; i++){
var totalOM= proj.renderQueue.item(i).numOutputModules;
for (var om= 1; om<=totalOM; om++){
var dateList, timeList, curItem;
if (proj.renderQueue.item(i).startTime != null){
var min = proj.renderQueue.item(i).startTime.getMinutes() <10 ? "0"+ proj.renderQueue.item(i).startTime.getMinutes() : proj.renderQueue.item(i).startTime.getMinutes();
var year = proj.renderQueue.item(i).startTime.getFullYear().toString().substr (-2,2);
timeList = (proj.renderQueue.item(i).startTime.getHours()-1)+":" + min;
dateList =proj.renderQueue.item(i).startTime.getDate()+"/"+(proj.renderQueue.item(i).startTime.getMonth()+1)+"/"+year ;
}else{
dateList = "not ";
timeList = "rendered";
curItem = folderPathListbox.add ('item', i ); // Column 1
curItem.subItems[0].text = om; // Column 2
curItem.subItems[1].text = dateList.toString(); // Column 3
curItem.subItems[2].text = timeList.toString(); // Column 4
curItem.subItems[3].text = proj.renderQueue.item(i).comp.name; // Column 5
curItem.subItems[4].text = proj.renderQueue.item(i).outputModule(om).file.toString().replace(new RegExp(",","g"), "\r").replace(new RegExp("%20","g"), " ").replace(new RegExp("%5B","g"), "[").replace(new RegExp("%5D","g"), "]"); // Column 6
}catch(err){alert(err)}
return folderPathListbox;
}var UI = createUserInterface(this,res,"Better RQ");
var myList = UI.folderPathListbox;
var lsRq = listRQ(myList);
//~ alert(lsRq.toString());{ // buttons action
UI.buttonGroup.buttonPanel.refButton.onClick = function () {
lsRq.removeAll();
listRQ(myList);
writeLn("all done");
UI.buttonGroup.buttonPanel.dupButton.onClick = function () {
var lstSlct = new Array ;
lstSlct = myList.selection;
if ( lstSlct != null){
var totalDup = lstSlct.length;
for (var i= 0; i<totalDup; i++){
var lsId = lstSlct[i].toString();
var dup = parseInt(lsId);
app.project.renderQueue.item(dup).duplicate();
writeLn("duplicated #"+dup);
}else{
alert ("select Something");
UI.buttonGroup.buttonPanel.selButton.onClick = function () {
app.project.renderQueue.showWindow(true) ; //shows the RQ
alert ("selButton");
UI.buttonGroup.buttonPanel.expButton.onClick = function () {
alert ("expButton");
catch(err){
alert ("Error at line # " + err.line.toString() + "\r" + err.toString());
