Activity Forums Adobe After Effects Selecting or changing only y position key frames
  • Selecting or changing only y position key frames
    Posted by Sion Shn on April 19, 2016 at 5:53 am
    I have a bunch of key frames, but if I wanted to make them all align to a single horizontal line, would there be an easy way to go about doing this?
    Lucas Feldman replied 8 years, 8 months ago 2 Members · 1 Reply
  • Lucas Feldman
    January 10, 2018 at 7:58 pm
    Right click the Position property and select Separate Dimensions. It will split the position into X, Y (and Z if it’s a 3D layer).
    Then you can select, copy/paste only one dimension of the Position animation and apply it to many layers. Works great.
    Only thing is it that it appears to remove easing (if you had any prior to separating dimensions), so you’ll need to re-do the easing before copying the new Y position, for example.
