Activity Forums Adobe After Effects selecting or adding effects fast
  • selecting or adding effects fast
    Posted by Chortorn on March 11, 2007 at 2:33 pm
    Is it possible to add a specific effect with a script?
    And is it possible to select the next or previous effect with a shortcut or a script?
    Chortorn
    Filip Vandueren replied 19 years, 6 months ago 2 Members · 3 Replies
  • Filip Vandueren
    March 11, 2007 at 8:38 pm
    Adding a specific script is very easy. See my post here:
    https://forums.creativecow.net/readpost/2/899776?pview=t#head
    Adding the next or previous is not a 1 step trick however.
    I suppose you want switch from say
  • Chortorn
    March 19, 2007 at 11:07 am
    Thanks for the answers.
    Actually I meant how it would be possible to switch the selection from one effect to another – ctrl+up/downarror switches the selected layer only. I found out that one way to select another effect by the keyboard be pressing f3 first, but I want to be able to select another property from the timeline window. Is it possible to do this with a script? selectedProperties is a read-only and therefore I find it troublesome.
    Is there a complete list of the script-names of all the effects?
    thanks in advance,
    Chortorn
  • Filip Vandueren
    March 19, 2007 at 12:44 pm
    Jeff Almasol made a reference list here:
    https://redefinery.com/ae/fundamentals/effects/matchnames.php
    This only includes all the Adobe Effects.
    Also if (on the mac) you press (Cmd+Shift+HELP) after effects writes a file with version info of all your plugins, but not their matchnames.
    BTW you can simply select a property by setting it’s .selected property to true,
    it will be added to the selectedProperties list.
    I’m not sure if After Effects will then automatically show it in the timeline though.
