Activity Forums Maxon Cinema 4D Selecting multiple objects on stage
  • Selecting multiple objects on stage
    Posted by Kelly Johnson on January 24, 2011 at 4:19 pm
    Is there a way to drag a selection around multiple objects on the actual stage? I’ve exploded an illustration and have around a million objects and obviously, weeding through by selecting in the structure tab is not that efficient.
    So far, I believe the selection tools are only for selecting pieces/edges etc on a single object selected for editing versus being able to ‘drag around’ and select actual objects.
    I’m in R10 and R12. Thanks
    Kelly Johnson replied 15 years, 7 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    January 24, 2011 at 9:09 pm
    You can use the selection tools for objects, but in the rectangle/lasso modes you’re basically selecting the objects’ axes. To that end, first select all the objects and run the Axis Center command. Then try loop/rectangle selection.
  • Kelly Johnson
    January 26, 2011 at 2:28 am
    Thanks…I see now.
