Activity Forums Apple Final Cut Pro Legacy Selecting multiple clips of same angle in multiclip?
  • Selecting multiple clips of same angle in multiclip?
    Posted by Sawi Hsiwi on May 20, 2013 at 9:21 pm
    Here’s my predicament. I have a 30 min seminar shot with two cameras: A & B. I created a multiclip from the two angles and made a sequence of clips as in the following: A,B,A,B,A,B…
    I now want to CC the separate angles. Back in FCP 7 I could correct the first clip and then use the find function and select all the other clips with the same name (usually it would be the file name created by the camera) and copy and paste the filters. However, in FCP X, all the angles in the multiclip now receive the title of the multiclip and not title of the source footage. Is there a way I can select multiple clips from the same angle in a multiclip without having to hold down the COMMAND button as I select them on the timeline or in the media browser?
    Nick Meyers replied 13 years, 4 months ago 2 Members · 1 Reply
