Activity Forums VEGAS Pro selecting colors with Vegas 5.0
  • selecting colors with Vegas 5.0
    Posted by Ronaldo German on November 27, 2005 at 1:25 pm
    Hi
    I just want to know how to select / isolate one color in a video file / event and let others be black and white, for example.
    I gess the way is through using secondary color correction, but how is the process?
    Thank you
    Ronaldo
    Ronaldo German replied 20 years, 9 months ago 5 Members · 5 Replies
  • Canadauser
    November 27, 2005 at 1:54 pm
    Simply select the “Color Corrector (Secondary)” video effect and drop it on the clip you want to manipulate.
    Then click on the eyedropper (where it says “select effect range”)
    Then move the cursor to your clip and select a range of colors you’d like to remove.
    Then go to the Saturation slider in the window and move the slider all the way to the left… you’ll see the color selected will now be removed from the clip.
    There are some tricks & tips when using this effect… for example… some shots are easier to remove colors from then others based on the complexity of the colors in the shot. It is very easy to remove greens and leave the reds (or vice versa) but difficult to remove one shade of red and leave another shade of red.
    Also, you can use this effect 2 or 3 times on the same clip to remove several shades of colors… but if you use this effect too much on the same clip… the quality seems to be affected as the clip gets grainy.
    Hope this helps.
    Paul
  • Jeremy Rochefort
    November 27, 2005 at 1:59 pm
    Edward Troxel has a great tutorial which can be downloaded from here:
    https://thetroxels.com/vegas/forum/viewtopic.php?t=19
    It mentions Version 4 but the workflow applies to V6 as well.
    Cheers
    Jeremy
    MJ Productions
    MJ Productions
  • Chris Young
    November 27, 2005 at 4:48 pm
    Try Moosehill Software. Karl Adahl developed a very good quick plugin for doing just what you want. Choose a single color and make the rest B+W.
    It’s called the ‘6cc’ six vector color corrector for Vegas. Very easy to use and you can find it at:
    https://www.moosehill.se/index.php?page=vegas/6cc.php
    Chris Young
    CYV Productions
    Sydney
  • Edward Troxel
    November 27, 2005 at 7:04 pm
    Vol 2 #10 of the newsletter gives the condensed Vegas 5/6 version plus a way to pass multiple colors.
    Edward Troxel
    JETDV Scripts
  • Ronaldo German
    November 28, 2005 at 2:02 am
    Thank you all very much.
    Best regards
    Ron
