Activity Forums Apple Final Cut Pro Legacy Selecting clips in FCP 6
  • Selecting clips in FCP 6
    Posted by Jim Settlemoir on August 9, 2007 at 12:43 am
    The manual (Vol. II, pg 172) says if no clips are highlighted and there are no In or Out points set in the sequence, FCP selects the clip beneath the playhead. In this case, for example, a filter chosen from the Effects menu would be applied to the clip beneath the playhead.
    I don’t find this to be true. When I’ve tried this, all the filters under the Effects menu are grayed out, presumably because no clip is selected.
    Am I doing something wrong?
    Jim Settlemoir replied 19 years ago 2 Members · 2 Replies
  • Tom Wolsky
    August 9, 2007 at 12:49 am
    Make sure the autoselect button is turned on for the track you want to apply the filter to.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Jim Settlemoir
    August 9, 2007 at 12:53 am
    Bingo. That did it!
    Thanks Tom.
