Activity › Forums › Apple Final Cut Pro Legacy › Selecting a timecode RANGE in a timeline
  • Selecting a timecode RANGE in a timeline
    Posted by Ed Yonaitis on December 28, 2010 at 4:27 pm
    I’ve recently taken on the task of onlining a feature edit, basically taking a DV sequence and relinking the clips to the respective HD footage. It’s not as simple as relinking the longer master clips to the HD counterparts, unfortunately; the conforming of the DV footage from 29.97 to 23.98 was done on a clip by clip basis, so basically every take in the movie has its own associated media.
    So I’m going through this edit clip by clip, and I was wondering if there was an option to select all clips within a range of timecode in a sequence, or even all clips associated with a particular reel? I’ve tried using the Find method but that only seems to allow you to search for a single timecode point.
    Example: I want to select all clips within my sequence within a source timecode range of 03:00:00:00 – 04:00:00:00. Is there a way to do that? If not, is there a way to select all clips in a sequence that are associated with Reel 3?
    Ed
    Ed Yonaitis replied 15 years, 9 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    December 29, 2010 at 3:07 am
    Not very easily. The easiest thing to do is make a new bin, select all the clips in your timeline, then drag the clips to this new bin. That way you can at least sort of reel/tc/whatever.
    Jeremy
  • Ed Yonaitis
    January 1, 2011 at 8:11 pm
    Yeah, I ended up figuring that out as the best thing to do–not perfect, but it definitely helped immensely.
    Thanks for the reply!
    E
