Activity Forums Adobe After Effects selecting a layer in the comp window?
  • selecting a layer in the comp window?
    Posted by Chris T on December 20, 2007 at 5:29 am
    ok, another simplish question. again i searched but to no real avail…
    OK – so i have a composition i’ve imported from photoshop. there’s about 50 discs on a plain background – each disc on its own layer. i can see them all in the composition window, but if i want to select a particular disc in that window i can’t select it in the comp window – i have to go through the layers on the timeline and click em on and off until i find the particular disc i want to manipulate. Is there a shortcut for this – a special click? The right click on the comp canvas and choosing ‘select’>’layer name’ doesn’t help me as i do not know which layer it is i want to select as far as names goes.
    Does this make sense?
    Basically I want an ‘auto-select layer’ function as there is in photoshop…
    Chris T replied 18 years, 9 months ago 3 Members · 5 Replies
  • Darby Edelen
    December 20, 2007 at 6:07 am
    [Chris T] “Basically I want an ‘auto-select layer’ function as there is in photoshop…”
    I don’t have AE in front of me right now, but I believe that is the default functionality in AE. You may be running into trouble if you didn’t import your Composition as Cropped Layers, in which case each of the layers may be taking up the entire space of the composition window (clicking anywhere would then select the ‘top’ layer). I wish I had AE in front of me right now to confirm my suspicion, but I’m sure someone else will be able to correct me if I’m wrong =)
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Chris T
    December 20, 2007 at 6:24 am
    ooh…cropped layers.
    aha – yep, i didn’t do that. each layer is taking up the entire comp.
    bugger…
    thanks for your help.
    does this mean i have to start my comp again, re-importing the psd as a ‘cropped layers’ comp. or is there a way to get ae to reconfig the file as a ‘cropped layers’ comp within ae without having to restart.
  • Darby Edelen
    December 20, 2007 at 6:34 am
    I believe you need to re-import your PSD as a composition with cropped layers.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Aharon Rabinowitz
    December 20, 2007 at 1:44 pm
    Unfortunately, this is How AE works. Especially without cropped layers. But even so, it doesn’t select by pixel – or rather it does, but whatever is on top will be selected.
    Welcome to the fun world of large and complex compositions.
    One thing you can do is lock any layers you don’t plan on manipulating. This will make them unselectable, and then the next one down will be selected when you click (I think).
    Aharon Rabinowitz
    Email: arabinowitz (AT) yahoo (DOT) com
    All Bets Are Off Productions, Inc.
    Creative Cow After Effect Podcast
    Internet Killed the Video Star: A Guide to Creating Video for the Web
  • Chris T
    December 21, 2007 at 9:24 am
    hmm yes,
    i re-imported with cropped layers, but as you say it is only slightly more helpful.. i’ll see if there any layers i can lock.
    but yes, a bit fiddly../
