Selected clips change when I shut down my project and re open
In desperate need of some help!
I had to re sync some footage in premiere pro using plural eyes. Once this was completed I imported the clips along with the new sequence into my main PP project. I then gathered the clips I needed and copied from my synced sequence into my main edit sequence. Job done. Or so I thought. When I saved and closed down, then re opened the project the clips had changed to the hand clap at the beginning which had a marker on it.
Is this a problem with markers that I don’t know about?
Any ideas?
ThanksGem
