  • Emma Woods
    May 9, 2018 at 8:57 am
    Hey
    I’m a PHP developer. PHP is much easier and also compatible than ASP.
  • Ron Lindeboom
    August 26, 2018 at 10:30 pm
    If it were me, I’d start with a WordPress backbone and use one of the free pagebuilders like Elementor or Brizy. Both are very intuitive and do a LOT of the heavy code for you. (With your coding skills you can use the pagebuilders and then add whatever code hooks you want to to make the work truly custom and yours.) You can subscribe to a web hosting company like Siteground.com who will install the WordPress engine for you free and will give you an SSL certificate as part of the service. Did I mention they are very cheap also? ????
    Best regards,
    Ronald Lindeboom
    CEO, Creative COW LLC
    Creativity is a process wherein the student and the teacher are located in the same individual.
