Activity Forums Adobe After Effects Expressions Select specific values and get the maximum value from the selection.
  • Select specific values and get the maximum value from the selection.
    Posted by Kyung Ko on November 12, 2019 at 2:43 pm
    Hi all,
    Here’s what I’m trying to do.
    I have 6 text layers and trying to get a longest width value from the only ones that are 100 opacity.
    Here’s the code I got so far and trying to get // parts.
    Please let me know if anyone has any advise. Thanks!
    t1_opc = thisComp.layer(“text1”).transform.opacity;
    t1_w = thisComp.layer(“text1”).sourceRectAtTime().width;
    t2_opc = thisComp.layer(“text2”).transform.opacity;
    t2_w = thisComp.layer(“text2”).sourceRectAtTime().width;
    t3_opc = thisComp.layer(“text3”).transform.opacity;
    t3_w = thisComp.layer(“text3”).sourceRectAtTime().width;
    t4_opc = thisComp.layer(“text4”).transform.opacity;
    t4_w = thisComp.layer(“text4”).sourceRectAtTime().width;
    t5_opc = thisComp.layer(“text5”).transform.opacity;
    t5_w = thisComp.layer(“text5”).sourceRectAtTime().width;
    t6_opc = thisComp.layer(“text6”).transform.opacity;
    t6_w = thisComp.layer(“text6”).sourceRectAtTime().width;
    // Select the text layers with 100 opacity from t1 - t6;
    // Add the selected text layers into the bracket bellow to get the maximum width from the selection.
    // max_w = Math.max(selection)
    max_w
    Kyung Ko replied 6 years, 6 months ago 2 Members · 5 Replies
  • Dan Ebberts
    November 12, 2019 at 6:54 pm
    I think I’d just keep track of the max as the expression chugs through the layers:
    myMax = 0;
    L = thisComp.layer(“text1”);
    if (L.opacity == 100) myMax = L.sourceRectAtTime().width;
    L = thisComp.layer(“text2”);
    if (L.opacity == 100) myMax = Math.max(myMax,L.sourceRectAtTime().width);
    L = thisComp.layer(“text3”);
    L = thisComp.layer(“text4”);
    L = thisComp.layer(“text5”);
    L = thisComp.layer(“text6”);
    myMax
    Dan
  • Kyung Ko
    November 12, 2019 at 7:29 pm
    Thanks so much for the solution Dan!
    It works like a charm! ☺
  • Kyung Ko
    November 12, 2019 at 8:11 pm
    I made it work with your solution and it’s perfect, but I have a question just for the learning purpose. ☺☺☺
    Instead of linearly tracking down(which I think is the best way), I was trying to use ‘for loop’ to find the text layers in 100 opacity, and add those to ‘Math.max(“selected object”.width . . . )’
    I wonder if it’s even possible.
    I recently learned ‘for loop’ while researching for the problem, and just want to see how it can be done if it’s possible.
  • Dan Ebberts
    November 12, 2019 at 8:21 pm
    Something like this should work:
    myMax = 0;
    for (i = 1; i <= thisComp.numLayers; i++){
    if (i == index) continue; // skip this layer
    if (thisComp.layer(i).name.substr(0,4) == "text"){
    L = thisComp.layer(i);
    myMax
    Dan
  • Kyung Ko
    February 6, 2020 at 7:23 pm
    Sort of late reply, but HUGE THANKS to Dan!!
    I’m learning a lot from you.
