Activity Forums Adobe Premiere Pro Select only slow motion clips?
  • Select only slow motion clips?
    Posted by Ivaylo Georgiev on October 10, 2024 at 10:17 pm
    In premiere pro, i have bin with 1200 clips from 3 cameras, some of them are shoot in slow motion 100 fps, other 25 fps. How to identify and select only slow motion clips in the bin? All clips appear 25 fps, but this filmed in slow motion mode plays in slow motion. I need this, because I need to change their speed to achieve Multi-camera synced clip. Multi-camera doesn’t work now because clips in slow motion have longer duration, and it’s a messy. When was filmed all cameras was synced to have same time code.
    Devrim Akteke replied 1 year, 10 months ago 2 Members · 1 Reply
  • Devrim Akteke
    October 11, 2024 at 7:59 am
    Unfortunately, I don’t know why, but sometimes Premiere Pro does not show the correct fps. Shows all 25. If somehow you can manage to select those shots you can select them in the bin and right-click and choose Modify-Interpret footage and Assume this frame rate to whatever you need. This way those will behave as you wish.
