Activity › Forums › Maxon Cinema 4D › select objects identical by geometry
Posted by Petcov Petru on June 14, 2016 at 10:23 amis it possible…so i say i have a lot of identical objects by geometry( but different sizes) is it a script or plugin which can do that – to select only those objects?
i found this,https://creativetuts.com/python-script-select-all-other-objects-which-has-same-size-of-selected-object/ but this script select objects by identical size
Kouraib Abdmalekreplied 1 month ago 5 Members · 7 Replies
Jim Scott
June 14, 2016 at 2:08 pmHere’s a quick tip that you may find useful. It will show you how to reveal (or hide) in the object menu, at which point you can simply select all of those objects you want to work with.
https://www.digitalsandwich.net/portfolio/c4d-quick-tip-hide-objects-by-type/
Petcov Petru
June 14, 2016 at 3:58 pmyes i know about that,thank you
but this is not enough – let’s say i have a complex building and i want to select only windows or maybe columns or other elements (this kind of objects i was referring to when i said – identical by geometry )in fact my goal is to turn those identical objects to instances
Adam Trachtenberg
June 15, 2016 at 2:54 amI don’t know of any function that searches for identical geometry, but I think it most cases where there are identical objects they should have the same names, or at least names that contain identical strings. If that’s the case then you can use the search function in the Object Manager (magnifying glass) to solo them in the object manager.
Petcov Petru
June 15, 2016 at 12:16 pmyes i know – in most cases yes but i have a scene which is imported from another software so almost all objects were imported with id000, id001 and so on
Petcov Petru
June 15, 2016 at 8:38 pmthis guy made,imho,a fantastic job…see it in the post which i’ve created here https://www.c4dcafe.com/ipb/forums/topic/93206-automated-objects-replacing-with-instances/
in fact that was my goal
Frankie De l
October 9, 2024 at 7:52 amHey! I know this is an old thread, but I was looking for this too, until I decided to give it a try with claude. I kind of did it, and it works most of the time, but maybe there is a better way. Also I included a script to get rid of empty nulls and nulls with just one child.
Kouraib Abdmalek
July 17, 2026 at 10:15 amHi Frankie,
Regarding creating a script that recognizes all elements of the same type, regardless of their properties, this is possible. I’ve done this on a newer version of Claude and it was completely successful. However, converting them into instance seems impossible because it’s illogical. Instance are used to replicate a single element in a scene, allowing you to control all the of them by modifying the original element’s properties. This also helps reduce file size and makes the scene lighter. It’s impossible to make elements with different properties as instance` of a single original element. Therefore, if we use your script, you’ll find that all the elements will become similar, with properties that are the average of the other properties to achieve this logical paradox as you’ll see in the attached screen recording. The good news is that AI-powered scripting for c4d has improved significantly with Claude, especially in later versions. Any option you can think of (provided it’s compatible with the program’s core system) can be added as a command to the program and have a shortcut created for it. I hope this is helpful.
