Activity › Forums › Adobe After Effects › Select multiple specific properties in a shape layer?
  • Select multiple specific properties in a shape layer?
    Posted by Tomas Brunsdon on October 6, 2016 at 4:01 pm
    Hello!
    Is there a way to select every instance of a property within a shape layer (eg. ‘Merge Paths 1’)- either through the timeline search bar or other means? Closest I’ve found is a script called bq_shape_layer-navigator but it doesn’t quite do this. Finding a quick way could potentially shave days off of this project!
    Roei Tzoref replied 9 years, 11 months ago 2 Members · 1 Reply
  • Roei Tzoref
    October 7, 2016 at 9:43 pm
    [Tomas Brunsdon] “Is there a way to select every instance of a property within a shape layer (eg. ‘Merge Paths 1’)- either through the timeline search bar or other means?”
    yes. you can search with the timeline search bar like this:
    is there a specific case where you can’t use it for searching?
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
