Activity Forums Adobe Illustrator Select multiple objects in Layers panel
  • Select multiple objects in Layers panel
    Posted by Paul Roper on February 21, 2014 at 3:14 pm
    Hello,
    This question has been asked many times, many years ago, but I can’t seem to find an answer.
    I can highlight a bunch of objects in the layer palette in any number of ways (most obviously click on one thing, then shift-click on something else and everything in between get selected). Because Illustrator is an evil, nasty piece of software, I cannot do the same with the selection circle in the layers palette. Am I right in assuming that the only way to convert a bunch of highlighted objects to a selection is by a silly workaround, such as selecting one object, grouping it, then highlighting all the other objects I want, then dragging them into the group, then ungrouping them? This was about the only workaround I could find, but it was from years ago. And ridiculous.
    Anyone got any better suggestions?
    – Paul
    Paul Roper replied 12 years, 7 months ago 2 Members · 2 Replies
  • Vincent Rosati
    February 21, 2014 at 8:53 pm
    Could you hold Shift + Option as you are clicking the layers?
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Paul Roper
    February 22, 2014 at 2:13 am
    Thanks for the suggestion, but that does allow me to select and highlight something without having to click the circle, but I still have to click each object individually.
    – Paul
