Activity Forums Adobe Illustrator Select layers with same name?
  • Select layers with same name?
    Posted by Greg Howell on February 9, 2017 at 10:08 pm
    Hi all,
    Here’s my problem…
    I have several hundred symbols as sublayers in layer 1. All the symbols are either Symbol 1’s, Symbol 2’s or Symbol 3’s. I want to split all the symbols into just 3 layers (layer 1 for symbol 1’s, layer 2 for symbol 2’s etc..) The thing is, is there all mixed up. How to I select all Symbol 1’s so i can move the layer order without having to go through and select each one individually?
    thanks in advance.
    Greg
    Vincent Rosati replied 9 years, 6 months ago 2 Members · 2 Replies
  • Vincent Rosati
    February 11, 2017 at 3:33 pm
    Select a symbol and try..
    Select > Same > Symbol Instance.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
  • Vincent Rosati
    February 11, 2017 at 3:38 pm
    Also, once an item or items is selected, in the Layers palette, a selected item indicator appears on the right side of the layer. It’s a small colored square. You can click and drag this indicator to the desired layer. This will move all items that are currently selected.
    Vince
