Activity › Forums › Adobe After Effects › select keyframes from a point forward?
Posted by Jeremy Webb on April 15, 2005 at 9:22 pmis there a way to select the keyframes from a point in time forward to the end for a given property?
Mike Clasby replied 21 years, 4 months ago 2 Members · 4 Replies -
Mike Clasby
April 15, 2005 at 10:10 pmI dunno if this is what you mean, but:
Select the layer(s) the keyframes are in.
Hit “u” to reveal all keyframes.
With your little arrow cursor, select the key frames from where you want to the end. You can drag a little marquee around the keyframes (like making a rectangular selection in PhotoShop), very fast and easy.
Jeremy Webb
April 15, 2005 at 10:23 pmno, i have a really long sequence, and lots of key frames, it’s a pain to keep zooming out to select them. wondering if there’s an easier way.
Mike Clasby
April 15, 2005 at 10:44 pmRight Click the keyframe and choose between:
SELECT PREVIOUS kEYFRAMES
SELECT FOLLOWING kEYFRAMES
Select Equal Keyframes
The first two choices are new with AE 6.5
If you don’t have 6.5, maybe your stuck doing the inverse of my first post.
Select the property, thus selecting all the keyframes, then deselect the ones you don’t want change with “Shift” and dragging a little marquee.
Otherwise, I dunno.
Mike Clasby
April 15, 2005 at 11:36 pmOr, if no AE6.5, Split the layer at the point you want to select all keyframes, then you can select all the keyframes (select the property) easily in the split layer that goes forward in time.
