Activity › Forums › Adobe Premiere Pro › select from here to end of sequence
  • select from here to end of sequence
    Posted by Jim on June 8, 2012 at 3:47 pm
    In FCP, pressing tttt in a sequence selected everything from that point till the end. Is there an equivalent function in PR CS6?
    Jay Rudin replied 11 years, 7 months ago 3 Members · 4 Replies
  • Stephen Smith
    June 8, 2012 at 7:30 pm
    A is the Track Select Tool. Hold down Shift and then it will select all tracks. Just like with the Blade tool. You can’t hit bb to get a double blade. YOu have to hit C and hold down shift. Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Jim
    June 8, 2012 at 10:59 pm
    Thanks for getting back to me. Perhaps I did not explain what I was trying to do. In FCP, if I wanted to separate an interview into just the answers, I would blade at the cut point and be able to hit the “t” key 4 times; this would give me a double arrow and when I clicked on the sequence (following the blade cut) it would select everything later. I could then shift the rest of the sequence down (without fear of putting anything out of sync etc) and insert a title or something else. Is there an equivalent function in PR CS6?
  • Stephen Smith
    June 22, 2012 at 2:58 pm
    Jim,
    I’ve been a FCP user since version 2. I like many others are testing out other NLE programs. Here is a video tutorial that will show you what you need to do.
    https://reels.creativecow.net/film/tttt
    Best of luck and hope this helps.
    Stephen Smith
  • Jay Rudin
    February 25, 2015 at 5:58 pm
    Jim,
    A bit late finding your post but I’m looking for the same feature. Did you ever find a way to select “from here” in Premiere? There was such a function in the old Media 100 and it made life much easier with long projects when trying to open up a gap and work withing a sequence.
    Have you had any luck?
