Activity Forums Adobe Premiere Pro Select every other clip – Premiere Pro
  • Select every other clip – Premiere Pro
    Posted by Filip Andersson on March 15, 2021 at 4:39 pm
    How do I select every other clip on a layer in my timeline?
    When I have really long footage (over 60 minutes) I prefer to add it to my timeline and play through it and add cuts using the Add Edit to All Tracks (Shift+Cmd+K) command. However, this leaves me with a timeline with a lot (probably 300+) of clips, and half of them (every other) are the parts that I want to cut out. Is there an easy way to select every other clip on a layer in my timeline and ripple delete them using the Ripple Delete (Opt+Delete) command? Going through and manually selecting every other clip is a nightmare.
    And please, I don’t want any tips on different editing methods, this is my preferred method of editing, I’m only asking for a way to select every other clip.
    Thank you.
    Filip Andersson replied 5 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
