Select event with out moving Playhead
Posted by Brad Leigh on February 4, 2014 at 6:13 amEvery so often I scub the playhead to the exact location I want and want to split an event that is not highlighted. Is there a way to do this without risking moving the playhead?
Bradi7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 12
Norman Black replied 12 years, 7 months ago 6 Members · 7 Replies -
Matt Carlson
February 4, 2014 at 9:03 amHold down CTRL when you are selecting and the cursor will not move.
Steve Rhoden
February 4, 2014 at 10:17 amMatt is correct. your Ctrl and Shift keys has many
additional functionality in Vegas.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
Roger Bansemer
February 4, 2014 at 11:46 amThis sounds interesting but I’m not quite following it.
Holding down the ctrl key duplicates the event.
Can you explain what you mention a bit more?
RogerRoger Bansemer – PaintingAndTravel.com
Graham Bernard
February 4, 2014 at 12:27 pmRoger, don’t MOVE the Event, otherwise you will get a copy. This is to only LOCK/FIX the Event from moving whilst wanting to Split it.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Steve Rhoden
February 4, 2014 at 12:45 pmWhen you hold down the Ctrl key Roger and select an event, the
cursor does not move. That’s what Matt was recommending.Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Brad Leigh
February 4, 2014 at 2:11 pmThank You all.
I’ll give it a shot.
Norman Black
February 4, 2014 at 5:39 pm[Matt Carlson] “Hold down CTRL when you are selecting and the cursor will not move.”
Yes, but if an event(s) is already selected it will stay selected. The Ctrl modifier is used to add more events to an existing selection.
This is standard Windows UI convention.
Ctrl+Click adds individual items to a selection.
Shift+Click adds to a selection where everything in between the current selection and the Shift+Click point is added to the selection.
