Activity › Forums › Apple Final Cut Pro Legacy › Select Clips By Resolution
  • Select Clips By Resolution
    Posted by Richard Sanchez on March 27, 2008 at 12:52 am
    I’m currently working on a program that is mixing Betacam SP, DVCPRO HD (On Tape) and DVCPRO HD (on P2). The DVCPRO HD material orginating on tape is offlined at DV, so it’s easy enough to identify by clicking on the clip item properties, but I wanted to know if there was a quick shortcut to select all clips by resolution. Using the find option I can find all by name, but that doesn’t help that much. Thanks!
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
    Arnie Schlissel replied 18 years, 6 months ago 3 Members · 2 Replies
  • Sean Oneil
    March 27, 2008 at 4:51 am
    You can drag them into a bin and sort it by resolution.
    Sean
  • Arnie Schlissel
    March 27, 2008 at 2:46 pm
    If you have that column showing in the browser, you can sort on it by clicking on the column heading. Clicking a 2nd time will reverse the sort order.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
