Activity Forums Adobe Premiere Pro Select clip Above/Below with Keyboard shortcut?
  • Select clip Above/Below with Keyboard shortcut?
    Posted by Craig Trayler on March 25, 2022 at 12:28 pm
    Am I going mad here 😱?
    Is there no keyboard shortcut to select a clip above or below the current active clip in the selected track?
    You can CMD + ⬆ CMD + ⬇ to select the next clip left or right in the same active track, but is there really no way to select a clip above or below with a keyboard shortcut?
    Craig Trayler replied 4 years, 5 months ago 3 Members · 5 Replies
  • Chris Wright
    March 26, 2022 at 12:46 am
  • Craig Trayler
    March 26, 2022 at 10:26 am
    Hi Chris, thanks for the link, I read that a while ago and is a nice read, but does not provide the answer I need, it’s just an article of an editors top 24 keyboard shortcuts that does not contain a resolve to my question.
  • Ann Bens
    March 27, 2022 at 7:03 pm
    That is correct, you find the answer because the kbsc does not exist.
    Post your request here: https://adobe-video.uservoice.com/forums/911233-premiere-pro
  • Ann Bens
    March 31, 2022 at 11:38 am
    Won’t find the answer…
  • Craig Trayler
    March 31, 2022 at 11:55 am
    Hi Ann,
    How can you say “you won’t find the answer because the kbsc does not exist.” when that is the answer.. My question was to confirm if there was or was not a keyboard shortcut for what I wanted, and I can now after researching elsewhere see there is not, and no coding way around it also sadly.
    My reference was that instead of getting a clear answer yes or no answer, I was given a link to a select amount of keyboard shortcuts.
    For comparison, if I was asking if anyone knew if there has ever been a world record created for longest distance a apple was chucked, and I was just sent to Guinness world records top 100 records, that would not be very helpful unless it was in the top 100 listings.
