Activity Forums Maxon Cinema 4D Select children with Hierarchy Node
  • Select children with Hierarchy Node
    Posted by Corrado Carlevaro on April 15, 2017 at 1:47 pm
    I have this list:
    Null
    –parent.0
    —-child.0
    –parent.1
    —-child.1
    –parent.2
    —-child.2
    –parent.3
    —-child.3
    –parent.4
    —-child.4
    Is it possible with an Xpresso Hierarchy node to select all and only the children?
    Thank you in advance
    Corrado
    Corrado Carlevaro replied 9 years, 4 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 15, 2017 at 7:40 pm
    I’m not sure if this is the only way, or the best way, but it seems to work if you use two heirarchy nodes.
    What I did is use one heirarchy node to address all the children of a null, and then feed that result into a second heirarchy node addressing the children of those children.
    File: 11263_heirarchnode2nodestoreachallsecondchildren.c4d.zip
  • Corrado Carlevaro
    April 16, 2017 at 11:02 pm
    Perfect!
    Thank you
    Corrado
