Activity Forums Adobe Premiere Pro select both video and audio tracks in premiere 2023
  • select both video and audio tracks in premiere 2023
    Posted by Philippe Verdoni on March 8, 2025 at 3:01 pm
    Hi, probably an unknowned command has modified the selection tool parameters but now it selects only the video track. How can I make it to select again both audio and video tracks at the same time? Thank you for your assistance
    Philippe Verdoni replied 1 year, 5 months ago 2 Members · 4 Replies
  • Ivan Eldredge
    March 8, 2025 at 3:15 pm
    Hello Philippe! It seems like Linked Selection might have been turned off, which would explain why you’re only selecting the video or audio instead of both together. Try pressing Shift + L to toggle it back on, or check for the icon in the middle of the ones that are on the upper left part of the sequence panel, if it’s not highlighted, click it to reactivate it.
    If that doesn’t solve it, the clips might have been unlinked manually. In that case, just select both the video and audio, right-click, and choose “Link” to reconnect them. That should get things back to normal!
    Best,
    Ivan Eldredge G.
  • Philippe Verdoni
    March 8, 2025 at 10:58 pm
    Thank you Ivan, I have a difficulty to find the icon in the middle of the ones that are on the upper left part of the sequence panel, could you be so kind as to provide a screen copy showing this icon.
  • Ivan Eldredge
    March 8, 2025 at 11:14 pm
    Sure, here it is.
    Best,
    Ivan Eldredge G.
  • Philippe Verdoni
    March 9, 2025 at 8:53 am
    Very nice Ivan, I had not noticed this tool before. Have a good sunday.
