Activity › Forums › Adobe After Effects › Select and drag multiple vertices w/ pen tool
Posted by Michael Osland on June 18, 2008 at 11:40 pmHey say I have a weird shape I drew with the pen tool. Is it possible to select and reposition only the left side? I know how to select multiple point by holding cntrl, then clicking and dragging so that rectangle selection box comes up, but I can’t move all these points.
Michael Osland replied 18 years, 3 months ago 3 Members · 6 Replies -
Mike Clasby
June 19, 2008 at 1:56 amM reveals the mask
Select the mask. All vertices are now selected.
Then with the selection tool, draw a little square around the points you want to move in unison. Now only those are selected. Drag one, and all move.
Michael Osland
June 20, 2008 at 7:59 pmIs it possible to just copy one anchor point and paste it into the next frame?
For example: Say frame 1 has a square and all the other frames have a square, but one corner is out of place. Can you copy the anchor point from frame 1 with the corner in the right place and paste it into the other frames, then delete the bad corners…so you are left with a perfect square?
Michael Osland
June 20, 2008 at 8:16 pmThanks, but I was trying to simplify my situation. I actually have rotoscope a moving animal. However, I made the mistake of being too precise when adjusting it. For instance, I really fined tuned every frame, so the leg appears to change shape.
I want to simply copy the mask area around the leg and make it the same for multiple frames so it doesn’t “jitter around” as much. However, I don’t want to lose the mask parts around the rest of the body.
Ron Lindeboom
June 20, 2008 at 8:40 pm[Dave LaRonde] “…that’s the danger of AE rotoscoping, because you can’t do what you want. Because each Mask Position keyframe represents a SET of mask vertices, you’ll have to change the bad mask vertices for every keyframe involved.”
Ah, Dave, the new Advanced AE Rotoscoping title from the Creative COW Master Series, featuring Pete O’Connell, has some strategies and ways that GREATLY speed up the roto capabilities of After Effects.
If you would like to do a review or just get to know it, please write Kathlyn, Dave, and let her know that you would like a copy. Give her your address.
I think you will be blown away by what’s on the DVD. I sure was.
Best regards,
Ron Lindeboom
Remember: Burt Bacharach lied. What the world really needs now is an undo button.
Michael Osland
June 20, 2008 at 8:54 pmAh thanks for the help. I feared that was the case. Oh well it’ll just take longer.
Thanks again
