Activity › Forums › Apple Final Cut Pro Legacy › Select all offline clips in a sequence
Posted by Dave Boampong on November 26, 2012 at 4:02 pmI was handed a sequence with some of the clips offline. They are mixed up throughout the sequence. Is there a way in FCP7 to search for and select only the offline clips in the sequence?
Dave
Dave Boampong replied 13 years, 8 months ago 3 Members · 5 Replies -
Shane Ross
November 26, 2012 at 4:08 pmSelect them and do what?
No, you can’t select only the offline clips in a sequence via a one button solution. You’d have to manually select them.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Dave Boampong
November 26, 2012 at 4:37 pmThanks Shane.
The idea was to select the offline clips and reconnect them to their media. I will do it manually then. Thanks again.
Dave
Steven Cohen
November 26, 2012 at 4:40 pmSelect all the clips in the sequence.
Go to reconnect them and then there will be 3 button on the upper right side.
Turn off the Online and Render buttons and it will only try to reconnect those that are offline.
Steve.
Shane Ross
November 26, 2012 at 4:52 pm
