Activity Forums Adobe InDesign Select a column from a tab delimited
  • Select a column from a tab delimited
    Posted by Thiery Roussel on November 14, 2013 at 1:35 am
    Q?
    Is it possible to select only one column of text separate by tab
    I’m in the process of creating a template for closing credits…. trilling!
    And I figure the tabs will be the simplest way to get the standard 2 columns.
    But I want to be able to select only the left or right column and apply a different character style.
    How do i get this?
    My dummy text is formatted like this;
    (tab) Title (tab) Full Name
    (tab) Driver (tab) John Doe
    Best
    Paul Fullilove replied 12 years, 10 months ago 2 Members · 6 Replies
  • Paul Fullilove
    November 14, 2013 at 3:13 am
    Hello. It looks like you might want to create object styles for each column. Check out the following:
    https://blog.lynda.com/2013/05/16/indesign-secrets-three-great-object-styles-for-any-designer/. It’s the third little (photo credits)tutorial in the video towards the end. You should be able to adapt that to what you need.
  • Thiery Roussel
    November 14, 2013 at 2:08 pm
    I get the tutorial. Not sure how this could help me.
    The two columns are in the same text box. And I want to select just one.
  • Paul Fullilove
    November 14, 2013 at 7:16 pm
    My mistake. I assumed that you used two text frames or two columns in a table. I would suggest that you pose your question to the indesignsecrets.com forum. That way David Blatner or others well versed in InDesign could help you out. Sorry.
  • Thiery Roussel
    November 14, 2013 at 7:51 pm
    Thank Paul for your ressources.
    I see how this would be easier to format if i had multiple text box, but i try to achieve the less copy&paste from an external document, wich introduce potential errors. If that path doesn’t work, I may go to different text box or tables.
    Best
  • Paul Fullilove
    November 14, 2013 at 8:23 pm
    Don’t give up hope yet. If you are copying and pasting from a word document DON’T. Use the Place command in the File menu. When the dialog box displays make sure you select the preserve text & table radio button. That way your word styles have a good chance importing intact. You can leave import styles selected. I always place in a text frame. If everything look kinda good then you can create your character styles. Anne Marie Concepcion has a great course on lynda.com that goes through this very process in detail. You might be able to view it without having to purchase anything.
    Good Luck
  • Paul Fullilove
    November 14, 2013 at 8:27 pm
    One more thing I forgot. Make sure you check mark show import options in the Place dialog box. If you don’t, you never get to the Place option dialog box.
