Activity › Forums › Adobe Illustrator › Select a column from a tab delimited
  • Select a column from a tab delimited
    Posted by Thiery Roussel on November 14, 2013 at 1:28 am
    Q?
    Is it possible to select only one column of text separate by tab
    I’m in the process of creating a template for closing ending…. trilling!
    And I figure the tabs will be the simplest way to get the standard 2 column.
    But I want to be able to select only the left or right column and apply a different character style.
    How do i get this?
    My dummy text is formatted like this;
    (tab) Title (tab) Full Name
    (tab) Driver (tab) John Doe
    Best
    Thiery Roussel replied 12 years, 10 months ago 2 Members · 2 Replies
  • Jonathan Ziegler
    November 14, 2013 at 1:35 pm
    Honestly, I think you’re better off using something like Indesign to do this. It has many detailed text tools that will really make the job easy. You can always import a PDF version back into Illustrator later on.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • Thiery Roussel
    November 14, 2013 at 2:00 pm
    thanks
    I’ll look for something like this into Indesign.
