Activity Forums Adobe After Effects Select 100 random layers?
  • Select 100 random layers?
    Posted by Don Jobs on July 13, 2017 at 10:30 am
    I have this script and it selects random number of layers:
    function selectLayers() {
    var myLayers = myComp.layers;
    min=1;
    max=myLayers.length;
    var myRandom = new Array();
    for (i=1; i <= myLayers.length; i++){
    myRandom[i-1] = Math.round((max-min)*Math.random());
    myLayers[i].selected = false;
    for (j=0; j <= myRandom.length-1; j++){
    myLayers[myRandom[j]].selected = true;
    selectLayers();
    How can I make it to select only 100 random layers?
    Thank You very much for your help! ☺
    Regards!
    Walter Soyka replied 6 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Mike Abbott
    July 13, 2017 at 3:13 pm
    6th line down:
    change to:
    for (i=1; i <= 100; i++){
    https://mikeabbott.info
    https://vantagegraphics.co.uk
  • Walter Soyka
    July 13, 2017 at 4:49 pm
    Here’s how I would approach it:
    function randomIndexSequence(numIndices) {
    // create a blank array
    indexArray = [];
    // fill the array with all the values from 1 to the numIndices argument to this function
    for (i = 0; i < numIndices; i++) indexArray.push(i+1);
    // shuffle the array by stepping through and swapping the value at each sequential position with a random position
    for (i = 0; i < indexArray.length; i++) {
    j = Math.floor(Math.random() * indexArray.length);
    swap = indexArray[j];
    indexArray[j] = indexArray[i];
    indexArray[i] = swap;
    return indexArray;
    function selectRandomLayers(layers, numLayers) {
    // get shuffled list of layers
    shuffledLayers = randomIndexSequence(layers.length);
    // step through the list of shuffled layers, and select the first n layers in that list, where n is the numLayers argument passed to this function
    for (i = 0; i < numLayers; i++) {
    if (shuffledLayers[i] <= layers.length) layers[(shuffledLayers[i])].selected = true;
    myComp = app.project.activeItem;
    selectRandomLayers(myComp.layers, 100);
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Don Jobs
    July 13, 2017 at 7:38 pm
    I love you guys!!!
    This is beautiful!
    Thanks a lot! 🙂
  • Don Jobs
    July 14, 2017 at 10:34 am
    I have one more issue please ☺
    Now I see that it works with all the layers in the composition including layers with the Shy switch On (Invisible in the list)
    I would love to make it work with only visible layers in the composition list.
    If it’s too much work, this is already perfect!
    Thanks again!
  • Walter Soyka
    July 14, 2017 at 2:30 pm
    Instead of building an array of all the layer indices to shuffle, let’s build a list of only non-shy layer indices. Then we’ll shuffle that:
    function shuffleNonShyLayerIndices(layers) {
    indexArray = [];
    // add each non-shy layer index to the array
    for (i = 1; i <= layers.length; i++) {
    if (layers[i].shy == false) indexArray.push(i);
    // shuffle the array of non-shy layer indices by stepping through and swapping the value at each sequential position with a random position
    return indexArray;
    // get shuffled list of layer indices
    shuffledLayerIndices = shuffleNonShyLayerIndices(layers);
    // step through the list of shuffled layers indices, and select the first n layers in that list, where n is the numLayers argument passed to this function
    for (i = 1; i <= numLayers; i++) {
    if (shuffledLayerIndices[i] <= layers.length) layers[(shuffledLayerIndices[i])].selected = true;
    Walter Soyka
  • Don Jobs
    July 14, 2017 at 2:55 pm
    Dear Walter,
    thank you very very much!!!
    I was really stuck and now I can proceed with my project…
    It’s working!!! (Off course ;))
    Thanks again!
  • Chad Ridgeway
    May 1, 2020 at 1:59 am
    Where would I apply this expression?
  • Walter Soyka
    May 1, 2020 at 3:35 am
    It’s a script, not an expression. Save it as a .jsx file, then run it through the File > Scripts menu.
    Walter Soyka
