Activity › Forums › Adobe Photoshop › seems that nobody can help me
  • seems that nobody can help me
    Posted by Harry Thomas on January 28, 2010 at 4:57 am
    I posted a problem not so long ago, still having problems. I am using Photoshop CS3. I want to make more than one line of text,
    on ONE LAYER. When drawing a text-box, and after typing in line one, I press enter, and expect the cursor to jump to the beginning of line two, which DOESN’T happen – it just ” hangs “. I then have to conclude the line one text, and go to the text tool again. It seems to make a new layer automatically, and I can type another line. And so forth.
    What I DON’T WANT IS MULTIPLE LAYERS each containing one line of text.
    What I DO WANT is multiple lines in ONE TEXT-BOX on ONE LAYER.
    I just don’t understand why this is a problem. My photoshop works well in all other areas. I have checked Preferences, but there’s nothing there to help me.
    Is there anyone out there knowledgeable enough, to understand why I may be having problems ?
    Thanks from Harry
    Patrick Gauthier replied 13 years, 6 months ago 6 Members · 6 Replies
  • David Bark
    January 28, 2010 at 5:29 am
    Press “Return” Instead of “Enter.”
    David Bark
    Lightshine Productions
  • Harry Thomas
    January 28, 2010 at 7:24 am
    does not work. All that pressing RETURN does, is to create spaces along line 1.
    I simply can’t get the cursor to jump to the begining of line 2.
    I assume that the RETURN key you speak of, is the Space-Bar. Is that what you mean ?
    Doesn’t work anyway.
    And the Adobe help section says, to press ENTER to go to the next line !! Go figure. Now I’m more confused, but still without a solution.
  • John Mensinger
    January 28, 2010 at 1:57 pm
    ^That.
    Plus, try NOT drawing a text box. Just click with the type tool to set an insertion point.
    Also, after entering a return to start a second line, you say your cursor doesn’t move down. Have you tried just typing anyway? Perhaps the cursor is moving down, but you have a screen redraw issue preventing you from seeing it. Be sure you have the latest driver for your display adapter installed.
    John M:
    All of the vim with none of that annoying vigor.
  • Richard Harrington
    January 30, 2010 at 10:05 pm
    Do draw a text block.. but make sure Leading is set to Auto in the type panel
    Richard M. Harrington, PMP
    Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Greg Barringer
    February 2, 2010 at 2:38 am
    Just drag the box and make it bigger.
  • Patrick Gauthier
    March 8, 2013 at 6:35 pm
    1- Create a text layer,
    2- write at least one word.
    3- Then, in the layers window, right clic on your text layer and select convert to paragraph text.
    4- Then clic on the text you write at step 2
    5- the text box will appear. resize it, it will be multiline.
