  • Posted by Gracias on April 1, 2005 at 11:15 am
    Hello,
    I find speed change is quite buggy. when ever I change the speed I get video Jittery.
    I checked my option Frame Blending Off. But I see the same stuff. Also what option do I ve to select for Variable or Constant. My source footage is DV.
    Do I have to render 8 bit Targa Cine YUV in my seq setting.
    Also I got the my other identical FCP G5 2.5, 2.5gb ram. I did not see this problem in tht machine.
    Regards
    Srinivas
    Walter Biscardi replied 21 years, 5 months ago 2 Members · 1 Reply
  • Walter Biscardi
    April 1, 2005 at 12:51 pm
    [Gracias] “I find speed change is quite buggy. when ever I change the speed I get video Jittery”
    You’re seeing interlacing issues. Depending on the speed, FCP does a good or not so good job of speed changes. If you want perfect slo mo, fast speeds or ramped speeds, then Twixtor is the way to go.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
