Activity Forums Adobe After Effects seemless loop rotation
  • seemless loop rotation
    Posted by Chris Mclaughlin on March 15, 2010 at 12:11 am
    Hi I am new to CS4 After effects and have read alot of posts about how to animate a circle into a seem less loop without any stutter at the beginning of the loop…I need some help because I think I am missing something…my footage is 4 secs long and is a circle….can anyone help with a simple tutorial on how to loop the circle 360 degrees seemlessly…I keep getting the stutter ….how do I set up my key frames…thank you kindly……also i notice when I import footage and my play head is at the beginning of the comp and it says its at frame 0…the footage seems just a little forward then the red line on the play head….should I move the footage right to the play-head red line??? is that messing up my loop
    thanks
    Lyndon Alvarez replied 15 years, 6 months ago 4 Members · 6 Replies
  • Joey Foreman
    March 15, 2010 at 12:34 am
    I don’t understand your question. What parameter are you animating?
    You have a simple circle. And you’re rotating it?
    Did you offset the Anchor Point so you can see the rotation?
    Please clarify and/or provide a screenshot or video capture.
  • Walter Soyka
    March 15, 2010 at 12:35 am
    Loops stutter when a frame is repeated. To avoid that stutter, you have to keyframe such that the last frame leads seamlessly back into the first frame. For example, if you are animating a rotation from 0 to 360 degrees and you want it to loop, the rotation on the very first frame of the comp should be keyframed at 0. The frame AFTER the last frame of the comp must be keyframed to 360 (or 1x). Just hit End to jump to the last frame, then Page Down to advance one frame beyond it.
    If you keyframe the last frame of the comp instead of the frame after it, then the loop will appear to stutter, because the last frame will match the first frame (both will have a rotation of 0/360 degrees), and the loop will seem to momentarily pause when they are played back to back.
    Walter Soyka
  • Joey Foreman
    March 15, 2010 at 12:41 am
    You can set the 2nd keyframe on the last frame of the comp, then move the end of the Work Area one frame back.
  • Walter Soyka
    March 15, 2010 at 12:46 am
    True. You could also jump directly to the time, or place the keyframes on the last frame and drag them one frame forward.
    Walter Soyka
  • Chris Mclaughlin
    March 15, 2010 at 4:23 am
    Hi Walter thanks for the quick response….very much needed info thank you and very straight forward….that works for me….creative cow to the rescue again…
  • Lyndon Alvarez
    February 8, 2011 at 3:30 am
    alt+click rotation stopwatch
    type: value+time*70
    change the number value for diff speeds
