Activity Forums Compression Techniques Seeking compression program for creating best quality flash encodings?
  • Seeking compression program for creating best quality flash encodings?
    Posted by Palius on August 12, 2008 at 4:30 pm
    Integrated Hardware/Software upgrade. New primary streaming format.
    Typical source/workflow: long form SD video, medium to poor quality, recorded to DVCAM; lightly cut on either Avid or FCP; special effects minimized for streaming delivery.
    Typical output: Flash video 640 x 480 or smaller streaming at not more then 1 Mb/S. Based on previous work with Real, QT, etc/SD video 1 Mb/S presumed well above leveling of bandwidth/quality curve–until testing shows otherwise.
    Software to run on Windows or MacOS (not necessarily both).
    Academic environment.
    Splitting each encode across multi CPUs/CPU cores better then software running multi encodings simultaneously. (i.e. 1 job at a time each turned around as quickly as feasible.)
    Your input appreciated.
    Regards,
    /mp
    Mark Palius
    Daniel Low replied 18 years, 1 month ago 2 Members · 1 Reply
  • Daniel Low
    August 12, 2008 at 9:31 pm
    For PC I’d be looking to evaluate Rhozet Carbon Coder, for Mac it would be Telestream’s Episode
    For high volume work add Carbon Server or Episode Engine.
    Both solutions are capable of splitting work across multiple servers AND cores.
    Both are capable of high quality output, however Episode has the edge when it comes to preprocessing features like advanced deinterlacing options.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
