* Seeking Advice. Fcp X event files turned black missing after using new version- Project no longer the same :(
I’ve come across some serious problems with FCPX the last two days. I will try to be as detailed as possible so maybe someone might have a solution. I began editing my music video on a hacked FCPX torrent V. 10.0.5. My friend then introduced the events on my external in his FCPX- but his is updated to 10.0.8. So when I tried opening back up my project on my macbook, I couldn’t open it back up unless I updated. Well I couldn’t update the hacked version, so I bought the 10.0.9. Once I opened the new version, my project was no longer the same. There were plenty of clips that were all black missing, especially Broll footage above the primary storyline. Also, I cannot break apart my compound clip. I started seeing hope when I found out I can transcode the black missing clips in the events to optimized and they would come back. However- 5 minutes in every time I’m transcoding/rendering, the force quit application error pops up saying ” Your Mac OS X startup disk has no memory available for application memory”. Can someone please suggest some ideas for me to get rid of this pop up error, transcode all my black clips to normal because the raw footage still does exist, and break apart my compound clip. More notes: My project was saved on my macbook pro hard drive and events are saved on my external hard drive. I think I only used proxies not optimized when I was editing. I tried relinking media.trashing render files, but somehow I believe my startup disc was never full until I bought the new version..I’m also really stressed because this music video is going to MTV but I cannot export it to TV specs because my project seriously got messed up. PLEASE HELP ME OUT, THANKS!
